Hi All,
Just trying to sort out a bit of much needed garage space and just wondered if anyone knew the rough length and width of a finished Roadster. Cheers |
Sure someone will measure theirs but from memory, mine was 10'10" x 5'8".
http://www.picturetrail.com/sfx/album/view/19919222 |
I could measure mine in the morning(not at home) if someone doesn,t give you the info sooner.
cheers andy |
I wonder if I can squeeez both the roadster and MK1 golf in the garage at the same time.. Think the golf is about 12ft long.. May even get my sapphire and roadster in at the same time. Must measure the max internal length but it's about 27ft...
As promised........
total width at extreme outer edge of the rear wings (widest point)= 172cm total length at very tip of front nose to edge of the rear tub at the lowest edge = 331cm These measurements were taken from a Roadster with the GRP rear tub. hope this helps. cheers andy |
Thanks for that, at least it should about fit in more tidying needed though!
Cheers |
| Thread Tools | |
| Display Modes | |
