Old 2nd April 2010, 08:13 AM
Default Propshaft.
Who's done the prop themself?
How did you go about it?
If not, who have you used?
Old 2nd April 2010, 08:35 AM
TSM Locost's Avatar
My join is approx 100mm from g/box end where i inserted an internal tube that was a tight fit into both halves of the prop, welded all round after having a 5mm gap between the 2 parts of the prop for penetration including spacer tube.
Be Lucky, Mike.
Old 2nd April 2010, 08:42 AM
I tried to modify my own Rob and at the time thought i had got it perfectly straight and the same orientation as the original - until my first drive.....
It nearly shook the car to bits at 40mph. For such a critical part it really is not worth trying to do yourself. Dunning and Fairbank in Leeds are really good and will supply a brand new prop for about £95. Very good they are to.
AndyH
Old 2nd April 2010, 09:09 AM
Yeah I have already e-mailed D&F. And your right £95 aint at all bad for a brand new item that's done correctly.
Once the car is rolling I will be measuring the installed dimensions and making arangments.
Old 2nd April 2010, 09:26 PM
drury318 drury318 is offline
I`ll second Nth West propshafts, rang them with dimensions and they made it within the hour then delivered it the next day, top class work and really helpful chap on the phone.
Dennis.
Old 3rd April 2010, 08:12 AM
dogwood's Avatar
dogwood dogwood is offline
I modded my own prop.
Worked out OK, no vibes at all.
The only prob with mine is I still got the rubber doughnut.
Now I got the new engine Im going for a new prop.
D&F quoted me the same price, with all new stuff.
So going with them when I get back....
David.
Old 3rd April 2010, 08:19 AM
Have D&F got a web site David ?
Failing that, has anyone got a phone number for them
Going to be in the same boat as you mate .... If I make my own. I am going to be stuck with that awfull rubber donut & it don't clear the tunnel enough for my liking
Hopfully, i'll be ready for my prop in the next few weeks
Old 3rd April 2010, 08:49 AM
dogwood's Avatar
Morning mate..
There ya go.
http://www.propshaft.co.uk/
David.
Old 4th April 2010, 11:52 AM
Silly question,do they use the old bits of original prop or are they completely new.
Reason for asking is that I have two props,one Sierra minus front doughnut and another minus the rear part, from center joint backwards so no diff flange.
Old 4th April 2010, 12:06 PM
All new for ~£100 which given how quick these two companies turn round seems excelent.
Perhaps we should try and organise a forum member discount with either of them..
Or a bulk Buy ( only problem being the difference in lenght. However all type 9's will use same construction.
