Old 7th April 2010, 04:39 PM
mdasseville mdasseville is offline
Question What shocks and springs
Hi All
come to the point when i need to buy shocks and springs,...what i would like to know is what spring rate,..i'm running a Yam R1 engine and a haynes chassis and sierra running gear.
i think i'm looking around 160-190lb on the back and 200-250lb front.
has anybody got this setup?
Mike
Old 7th April 2010, 04:55 PM
Hi Mike,
the figures you,ve quoted for the rears is far too softly sprung, as you,ll have 2 people plus the fuel tank & all the running gear I would suggest 250lbs on the rear.
As for the front, most folk with a car engine use between 300 to 350 lb springs so as you.re using the bike engine maybe 250lb on the front too.
Old 7th April 2010, 06:18 PM
i have got 350's on the front 200's on the back but thats with a pinto upfront. seems ok but i have nothing to compare it to.
i would guess 250-275 on the front due to the reduced weight.
Old 7th April 2010, 06:31 PM
is there any way to work out the LBs' of a set of springs. I haev some second hand ones that came of a Westi or something but not sure on teh springs..
Old 7th April 2010, 06:34 PM
most springs have the spring rate engraved on the bottom flat ( spring seat)
Old 7th April 2010, 06:36 PM
will have a butchers when the kids have gone to bed. In the back of the galaxy at the moment, I have brought back a load of stuff that's been delivered to work over the last few months for all the projects.. not sure where it's all going to go
