Old 8th April 2010, 08:19 PM
squbti's Avatar
squbti squbti is offline
Post drill size
hi guys, does anyone know what size drill i need for the mushroms before useing the reamer?
Thanks
samy
Old 8th April 2010, 08:28 PM
gingea1pom's Avatar
Samy,
Are you making your own mushroom inserts and reaming for the transit drag link or are you talking about reaming out the Sierra upright to take the Maxi ball joint?
Cheers Ginge
Build Pictures
Old 8th April 2010, 08:53 PM
squbti's Avatar
hi Ginge,i´m making my own mushrooms & they are looking good . i have drilled the offset holes with a 12mm drill & was going to go up to 15mm before tapping them but wasnt realy sure.
samy
Old 8th April 2010, 09:05 PM
gingea1pom's Avatar
Samy,
I’ll wined my neck in then as I purchased/cheated.
Cheers Ginge
Build Pictures
Old 8th April 2010, 09:32 PM
samy
15mm for the hole is correct, then ream out so the top is 17mm.
Not sure if you have the drawing but it's in there.
Mushroom inserts.pdf
