what is the diffences between the roadster chassis and locost chassis(ron champion) because i have a shot at a pre built chassis no engine mounts welded just a complete bare chassis is the locost chassis adaptable with out to much hassel for indy rear suspension cheers
jay |
You will find yourself doing a lot of refabricating, the roadster is an all together beter design.
There is a Sierra IRS on a Locost chassis design called Rorty Locost:
http://www.locost7.info/files/suspen...RSAssembly.pdf It looks quite similar to the Haynes Roadster rear suspension, I guess you'd be able to adapt some of the Haynes components, rear uprights and maybe wishbones. Keep in mind that Locost is 2" narrower than Haynes, you might have to shorten the Sierra driveshafts.
Albert Haynes Roadster FAQ | Haynes Builder Locations Gallery, build thread in Lithuanian / via Google Translate. |
The Roadster is also 4 inches longer .
cheers andy |
| Thread Tools | |
| Display Modes | |
