Old 12th April 2010, 04:51 PM
Default oil pressure / temp gauge
Hi all,
I,m about to fit an Oil pressure gauge & an Oil temp gauge, obviously I know where the original pressure point is on the block, so was thinking if its poss to fit both senders for pressure & temp from the same place on the block, or is there another outlet i should use for the oil temp sender?
I,ve read that i would need a "sandwich plate fitting" to connect both from the same outlet but its very close to my engine mount & don,t think i,ll be able to fit anything that size so close to the mount.
any suggestions ?
engine is the 1.8 CVH
Old 12th April 2010, 05:15 PM
Sandwich plate sits in between the oil filter and engine. I had one on my MR2 turbo for oil pressure and temperature. Super handy. Shame the Ford fitting isn't the same as a Toyota.
http://cgi.ebay.co.uk/SANDWICH-PLATE...mZ360249743117
Old 12th April 2010, 05:22 PM
ahhh, cheers deezee, i thought the sandwich plate went where the original pressure sender is,
that helps as i think there,s more space at the filter
Old 12th April 2010, 05:29 PM
where do i get a sandwich plate from?
Old 12th April 2010, 05:49 PM
Ebay, Burtons, Rally design anywhere like that.
Old 12th April 2010, 06:19 PM
gingea1pom's Avatar
Andy is this the sort if thing you are after.
Cheers Ginge
Build Pictures
Old 12th April 2010, 06:32 PM
NOOOOOOOOOOOOOOOOOOOOO
Oil cooler sandwich plates are for use with an oil cooler only. Do not try and plug sensors into them. Otherwise the oil can't reach the filter!
Oil cooler sandwich (note oil MUST flow out out)
Oil filter sandwich (Note the oil flows past the sensors and into the filter)
Old 12th April 2010, 06:37 PM
All that hassle for a sandwich....
Old 12th April 2010, 07:44 PM
I think you can get them from subway
Old 12th April 2010, 08:19 PM
gingea1pom's Avatar
Every day is a school day
Build Pictures
