Old 13th April 2010, 01:04 PM
Jimmyd Jimmyd is offline
Default Front suspension bracket layout, confused
Ok I wasn't 100% happy with the alignment of my front suspension and have decided to cut the brackets off. I had the David Murray jigs laser cut and I'm ready to go again but I'm having a mental block wilst looking at the positioning diagram on page 47. See attached.
Should the measurement i've marked as A,B&C not equal A,D&C?
A to B = 83.5 + B to C @ 108 = 191.50
A to D = 28 + D to C @ 155 = 183.00
Is A to B correct at 83.5? I'm sure I must have went wrong here 1st time around.
J
Old 13th April 2010, 01:17 PM
Yeah, your reading the drawing wrong. A-B (or the 83.5 dimension) is not to where C starts. Its reffering to the top of the chassis and not to wishbone mounts. A-B is 75mm.
Old 13th April 2010, 01:27 PM
Told ya mental block, couldn't see the wood for the trees. Many thanks
