Old 20th April 2010, 08:27 AM
Default Oh Yeah.... it will deffo fit
So if your ever tempted by Car Builder Solutions to get a wiggly hose, the kind that will defiantly fit over a 32mm pipe, take it from me, its the worst fit ever!
Now it clearly will fit, but this is as far as it goes. Save yourself the hassle and bother and get some proper hose elbows.
Old 20th April 2010, 08:30 AM
warm it up it will stretch.
Old 20th April 2010, 08:31 AM
And WD40 the rubber.
Old 20th April 2010, 08:55 AM
This was after it was sat on my radiator! I took my calipers to it and it only measures 26mm ID. I would have thought any 32mm hose would be around 30mm ID.
Old 20th April 2010, 09:29 AM
Thats a big stretch Deezee, from my experience the constant heating and cooling will perish the stretched rubber over time and it may crack.
Not worth the risk Deezee......AndyH
Old 20th April 2010, 10:34 AM
Jimmyd Jimmyd is offline
I wonder if you were sent the correct one? Sizes seam way out, I'd check with them and if it's correct ask for a refund as it's not even close to the discription on ID size stated in their discription.
J
