Old 23rd April 2010, 06:46 PM
Peter-C Peter-C is offline
Default Another pedal box question
Today I've started on my pedal box but for the large plate I haven't any 3mm. I've loads of 2mm. Could I use one with some support or maybe two of these instead ?
Peter
Old 23rd April 2010, 07:05 PM
The pedal box takes quite alot of pressure when you jump on the brakes so i wouldnt think 2mm would be up to the job
I would personally make the effort to get hold of some 3mm plate rather than double up the 2mm, Its a car you will have for years to come so just do it proper first time round
Its alot easier than doing it at a later date when its on the road
Old 23rd April 2010, 07:24 PM
dogwood's Avatar
dogwood dogwood is offline
3mm??
My brake and clutch pedals are 5mm
the throttle is 3mm, not quite so much pressure on that one..
.well most of the time
David.
Old 23rd April 2010, 08:35 PM
Originally Posted by dogwood View Post
3mm??
Pedal box, not pedals!
Same here though, 3mm for the throttle, clutch and brake out of 5mm, the clutch seemed a bit flimsy out of 3mm
Old 23rd April 2010, 11:33 PM
dogwood's Avatar
OOOOPS.......
David.
Old 24th April 2010, 12:18 AM
It is too flimsy out of 3mm, had to upgrade mine as it would easily bend. Make them all out of 5mm now just to be sure. But yes 3mm for the backplate to.
AndyH
Old 24th April 2010, 12:38 PM
Cheers Lads
