Old 27th April 2010, 03:33 PM
Jimmyd Jimmyd is offline
Default Have you made your own steel petrol tank?.......
...... if so what thickness of sheet did you use? The closest stockest to me has 0.8mm & 1.5mm at good prices but I would have thought something about 1-1.2mm would of been better. Is 0.8 up to job? Is 1.5mm to much?
Any thoughts welcome. Yes I probably should go the alloy route but can't weld it myself and it'll cost me at least 3 times as much by the time someone does it for me. Budget's very thin these days!!!
J
Old 27th April 2010, 03:53 PM
Tilly819 Tilly819 is offline
for referance my tank is 1.6mm ally so i would have thought anything around 1mm steel would be fine, dont forget to put in a couple of baffles but if you are using a laver arm sender make sure you leve enough room for it to move and if you are using an in tank pump its worth mounting a thicker plate onto the bottom of the take so when you bolt,/riv nut etc it does not deform the bottom of the tank like mine did....oops
hope this helps
tilly
Old 27th April 2010, 09:25 PM
dogwood's Avatar
dogwood dogwood is offline
I made mine out of 0.9mm steel.
Welded no probs.
David.
