Old 29th April 2010, 03:36 PM
Peter-C Peter-C is offline
Default Pedal bushes
Has anyone going to Stoneleigh got any spare pedal bush material ? I'll be there on Monday.
There should be a picture of my badge attached.
Peter
Old 29th April 2010, 05:42 PM
Jimmyd Jimmyd is offline
Powler,
I'll not be at Stoneleigh but I can post you a bit of Oilion if you don't get sorted. I think it's only 20mm od so it will depend on the id size of your bush tube as to weither it will leave you enough shoulder on the bush. It did me fine but I had actually meant to get 25mm od. Just had brain fade the day I went to get it
J
Old 29th April 2010, 08:20 PM
onedayTM onedayTM is offline
Hi pete, I've still got some acetal material left, if I can find it you can have some. I will probably be there Mon. I will look out for you/
tony
Old 29th April 2010, 09:46 PM
Coozer's Avatar
Coozer Coozer is offline
I have some oblong bits of white nylon if thats any good?
MNR Vortx Build Diary
www.mymnrvortx.blogspot.com/
Old 4th May 2010, 12:57 PM
Hi pete,
Tony here, didn't get to stoneleigh till noonish on Mon and didn't get chance to look for you, if you still need pedal bush material then pm me your address and I will sent it to you.
tony
