Old 1st May 2010, 06:47 PM
asennad asennad is offline
Default Modifying the IRS for a North American donor.
Last month while I was in the UK I had the great pleasure of visiting Saturn Sports Cars.
( I just happened to be in Hartlepool because that’s were my father’s family is from.)
I was given a remarkable ride in one of their cars:
http://www.youtube.com/watch?v=iSeE-dkV4cg
I am currently building a Locost here in Toronto and have been searching for a solid axle but after seeing the Haynes Roadster in person I am really interested in using the IRS design from it.
The Sierra ( aka Merkur) rear diff is very had to come by here and they were never produced in a limited slip version in North America.
Any suggestions for alternative donors that would be found here?
I am wondering if Nissan 240SX diff would work. Similar size and weight but slightly different drive shafts arrangement.
Old 1st May 2010, 07:19 PM
GraemeWebb's Avatar
[quote=asennad;37372]Last month while I was in the UK I had the great pleasure of visiting Saturn Sports Cars.
QUOTE]
I am wondering if Nissan 240SX diff would work. Similar size and weight but slightly different drive shafts arrangement.[/
I'm using a BMW 318i donor and have done some mods to the chassis to fit it. I dont know the Nissan that well but with a bit of thought I'm sure it will be do'able.
Old 1st May 2010, 07:33 PM
A Merkur Scorpio would be fine.
MK5's have been talked about
But E30/36 is the main alternate choice.
Old 2nd May 2010, 02:18 AM
Tim Taylor Tim Taylor is offline
Mazda Miata MX5 is a popular donor. I'm using an XR4Ti. There are several aftermarket LSD replacements for the Ford 7.5" diffs
Old 2nd May 2010, 08:34 PM
For a book and online build log of a Miata locost build, see http://cheapsportscar.net/
Old 2nd May 2010, 10:32 PM
Do you have any links or builders logs where I can learn more about using the BMW rear end?
Old 2nd May 2010, 10:37 PM
GraemeWebb's Avatar
I am using an E36 donor so you can look at my flicker pictures via the link below. In another week I should post pictures of the beemer front uprights.
Old 3rd May 2010, 09:21 AM
Freelander ? by Land Rover
Old 5th May 2010, 08:46 PM
7ishNZ 7ishNZ is offline
I am using a Nissan R200 lsd in my build.. ratios are available from 3.5 to 4.8 and viscous LSD centers are very cheap. Problem is, it is very heavy.. about 40kgs.
I am about to replace it with a subaru R160 lsd. This weighs 22kgs. In the USA you should be able to find plenty of Subaru diffs in a wide range of ratios. Hope this helps.
http://lotus7.co.nz/forum/viewtopic.php?f=16&t=72
