Old 5th May 2010, 11:22 AM
Tatey's Avatar
Tatey Tatey is offline
Default Aluminium Steering Rack Mounts
I'm trying to put the steering rack mounts onto my steering rack. The smaller mount went on no problem. However the larger one is really tight up against the steering rack and looks like its going to require a bit of force to get it to sit properly in place.
Have other people had this problem?
Is it ok to file down the mount slightly to allow it to fit on?
Old 5th May 2010, 11:56 AM
Exactly what I had to do. Think it's quite common. I also had to add extra packing under the plastic spacers to take up the slop.
Adrian
Old 5th May 2010, 11:57 AM
Try a little bit of washing up liquid and use the bolts to pull it hard up.
Old 5th May 2010, 12:16 PM
Jimmyd Jimmyd is offline
Yep same here, it was a tight fit. I don't see that a bit of a fettle with a file should make any real difference. Don't forget your plastic spacers underneath.
J
Old 5th May 2010, 12:21 PM
I too had this problem, a few strokes of a file sorted it, but don,t go mad on removing metal, it does need to be a "snug" fit .
Old 5th May 2010, 12:26 PM
whacked mine with a rubber mallet. could of pushed mine on by hand if i really wanted to but im lazy.
Old 6th May 2010, 05:41 PM
Peter-C Peter-C is offline
My rack and brackets arrived today - exactly the same. Squeezed the bigger one on with the vice.
Old 6th May 2010, 06:54 PM
I got a cheap Robinhood one, yet to see if they are any good!!
