Old 6th May 2010, 01:23 PM
davidimurray's Avatar
Default Fan Belts
Having made up my alternator bracket last night, i wrapped a bit of wire around all the pulleys and worked out that I need a belt which is approimately 860mm inside circumference. Just popped to halfords at lunch to find they have an abysmal selection of belts totalling 3 to chose from!!!
Does anyone happen to know what section belt the pinto pulleys take? I spotted these on bearing boys that would be ideal - http://www.bearingboys.co.uk/AX34_Cogged_V_Belt-11136-p
Does anyone know if that section belt will fit?
Old 6th May 2010, 01:25 PM
i used an 875A from halfords. works fine. i have got an 865 that didnt fit mine if you want that.
Old 6th May 2010, 03:16 PM
DStanley1809's Avatar
DStanley1809 DStanley1809 is offline
My Halfords computer system is saying 875B, £3.99.
I don't have one to look at but comparing other belts of the same the numbers (687A vs 687B etc) the only difference is a very slight difference in width. B is about 1mm wider.
Old 6th May 2010, 07:58 PM
Enoch Enoch is offline
I've got hundreds of belts in stock, I will have a look tomorrow and see aht I have in that length, if you like.
Enoch.
Old 8th May 2010, 09:06 AM
RAYLEE29's Avatar
RAYLEE29 RAYLEE29 is offline
Sounds like you went to a small store the one i work in has has loads of belts ranging from 600 up to about 1830 and a, b, c, and 3pk 4pk 5pk etc it is a superstore though Ray
Total spend so far £1116.08
1ST ALBUM HERE
2ND ALBUM HERE
Old 8th May 2010, 09:24 AM
We have an 863 in stock, have pm'd you.
If anyone else needs any belts have a look here:
http://enochsemporium.co.uk/index.ph...ort=20a&page=3
We don't have a huge stock but you might find what you need in there.
Enoch
Old 8th May 2010, 01:04 PM
A lttle off topic I know
I have just spent a good while browsing Enochs Emporium .... Blooming heck mate, you have something in there for everyone
Darn near caused a fight here !!?? .... I want a petrol hedge trimmer for Junior to use in our garden & Yep you have guessed right, Junior wants the Speedboat
