Old 8th May 2010, 06:17 PM
steve8274 steve8274 is offline
Default wanted/needed steering colum mount
hi all
i need a steering column mount! not sure what it is called properly but i need one.
i have just realised i have made a very stupid mistake.
stripped my donor ages ago, been checking other peoples build pics and realised i have thrown away steering column mount.
in case i havent described it correctly its the bit which the steering colum fits through, then that is bolted to frame.
help would be very much appreciated
thanks
steve
Old 8th May 2010, 06:58 PM
I think you are after this bit? Its very rare to find without a complete column attached! Mine was broken, so I made a new one.
Old 8th May 2010, 07:32 PM
yes that looks like the one. dont fancy paying for whole column tho. see if i can get one made up
thanks
Old 8th May 2010, 09:57 PM
Enoch Enoch is offline
I have got a complete steering column with switch going spare. The only problem is the steering lock does not work - I think there may be a spring missing. If you remove the lock barrel you can make the lock engage but it does not engage automatically when the key is withdrawn. It's got the steering wheel with it, it's yours for £20 plus post if you want it.
Enoch
Old 9th May 2010, 10:26 PM
hi enoch.
think i may have a bracket sorted now but if it doesnt happen then i will contact you and take yours if thats ok
thanks for replying and offering help
steve
