Old 14th May 2010, 04:26 PM
filip arvidsson filip arvidsson is offline
Default Rear upright - 12mm internal tube
Hi!
Is it important to have a 12mm internal pipe for the upright?
I got some 20*2 tube left and the drilled hole in the plates should keep the bolt in centre.
Thanks
//Filip
Old 14th May 2010, 06:09 PM
It'll be fine Filip, its only there to serve as a crush tube / spacer when you tighten up the bolt holding the rear lower wishbone attached....
AndyH
Old 14th May 2010, 07:06 PM
Awesome, thanks!
