Old 19th May 2010, 09:03 PM
onedayTM onedayTM is offline
Default bellhousing location pins.
Hi guys.
I read somewhere that if your fitting zetec to sierra gearbox that you need to use pinto location pins as zetec ones are to big. Can anyone confirm this ?
tony
Old 19th May 2010, 09:42 PM
Big Vern Big Vern is offline
There's only one size that fits the type 9 bellhousing so you'll need to use those. Remove what ever is in the Zetec. From memory the blacktop ones are bigger though the smaller ones can be used. (the FWD ones are large diameter but narrow - the RWD ones are smaller diameter but wide, if that makes sence).
HTH BV.
Old 19th May 2010, 10:56 PM
cheers vern, I'll have a look and check them out.
tony
