Old 23rd May 2010, 07:59 AM
Tatey's Avatar
Tatey Tatey is offline
Default M12 Studding - Best place to buy?
I'm close to putting on my suspension brackets and I'm wondering where the best place to buy some M12 studding is? Having a look on ebay it seems quite expensive for what it is.
Also how much studding is needed to get the suspension brackets sorted?
Old 23rd May 2010, 08:13 AM
I have som from B&Q, but any local steel stockholder will have it. Thomas Graham here is my source.
Old 23rd May 2010, 08:15 AM
http://www.diy.com/diy/jsp/bq/nav.js...+rod&x=0&y =0
Old 23rd May 2010, 08:59 AM
Tatey's Avatar
It would have helped if I called it threaded rod instead of studding . Cheers TT.
Old 23rd May 2010, 09:10 AM
yeah, depends what peeps fancy calling it.
Old 23rd May 2010, 09:48 AM
tkpm tkpm is offline
Your local builders merchant should keep it in stock, as it's use a lot in the building trade.
Terry
Old 23rd May 2010, 08:30 PM
RAYLEE29's Avatar
RAYLEE29 RAYLEE29 is offline
I got mine from the local inexcess for about £2
Ray
Total spend so far £1116.08
1ST ALBUM HERE
2ND ALBUM HERE
Old 23rd May 2010, 10:37 PM
Minicooper Minicooper is offline
I don't know if you have a Toolstation branch near you but they do a 1 metre length of M12 threaded bar for £1.55
http://www.toolstation.com/documents...r=threaded+bar
