Old 23rd May 2010, 02:19 PM
daveandjoe daveandjoe is offline
Default Zetec flywheel
Just removed the flywheel from our Zetec in order to fit a torque converter and we found an electronic sensor behind the flywheel.
Can anybody tell me is this just to fire the rev counter or is it some complicated part of the injection system?
Zetec virgins
Old 23rd May 2010, 03:22 PM
David_17's Avatar
David_17 David_17 is offline
That's the crank position sensor. You won't get a spark without that.
Old 23rd May 2010, 03:24 PM
Big Vern Big Vern is offline
This is the crank sensor for the ignition system. It also gives a speed signal to the fuel injection system. They may be different auto to manual so you'll need to check the part numbers at your local ford dealer
Old 23rd May 2010, 03:29 PM
Thanks for the answers guys
Does anyone know how it works on an automatic?
Zetec virgins
Old 23rd May 2010, 08:56 PM
Jimmyd Jimmyd is offline
The same way as it does on a manual I'd say. The crank position sensor is linked to the ECU to control spark or spark and fuel on a fuel injected engine. I don't believe it will have any other effect on an auto. You just need to be sure the pick up point on the torque converter is at the same point as it was on the flywheel. If not you can always mount a trigger wheel and sensor to the front bottom pulley. You can do a search on fitting megajolts or megasquirts to get some ideas .
J
Old 24th May 2010, 09:53 AM
thanks jimmy
Zetec virgins
Old 26th May 2010, 11:05 PM
tex tex is offline
if memory serves me there are 2 sensors.. Longer one and shorter one.. Dunno which ones for which now
