Old 23rd May 2010, 08:55 PM
Peter-C Peter-C is offline
Default Master cylinder pivot
HI'
Has anyone made there own pivot that fits between the brake pedal and the master cylinder ? Or did you buy it ?
Peter
Old 23rd May 2010, 09:36 PM
drury318 drury318 is offline
Hi Peter, yes I made mine from an old front pipe retaining bolt off a zetec as I had a few kicking about, the ones that are a loose fit held in with a spring clip and a pin.
I cut it down leaving the threaded part on which acts as an adjuster, then cut a slot for the pedal with a slitting disc. I refused to pay silly money for one from the normal kitcar sources, Dennis.
Old 23rd May 2010, 10:01 PM
Enoch Enoch is offline
I made mine too. I cut the head off a long bolt and then made a clevis out of a bit of 1/2 inch square steel. Works a treat and costeth not a lot
Old 23rd May 2010, 11:06 PM
Cheers lads,
I'll have a go tomorrow
Peter
Old 24th May 2010, 12:45 PM
carlknight1982's Avatar
Brought mine from Rally design, cost about £4 I think
Old 25th May 2010, 07:45 PM
I've made my pivot and mocked up the pedal assembly. Do I need the full travel of the piston in the master cylinder - its about 30mm ? Because if I do the pedal is well facing forward. Looking at photos of other boxes it seems that all of the travel isn't used. Any ideas ?
Peter
Old 25th May 2010, 08:47 PM
In my car the brake is full on after just a few mm of movement of the master cylinder piston. I have a little bit of slack in the pedal but I reckon the top of the pedal only moves about 25-30mm from rest to full on. Hope that helps.
Old 25th November 2012, 05:45 PM
jps jps is offline
Another ancient thread resurrection I'm afraid (the search function alone makes this forum worth the weight of a Haynes roadster in gold i reckon)...
I've made my pedal box and offered the brake master cylinder up to it today. I was wondering how the vertical movement of the hole in the brake pedal (ie, the hole that the clevis goes into must move up and down slightly as the pedal rotates around its pivot in a curve?) works with the fixed horizontal movement of the brake cylinder piston....
Is the vertical movement so negligible that it doesn't matter?
Old 25th November 2012, 06:29 PM
negligible ...yes but it does still need to move up and down a little.....if your hole is drilled "clear" then should be enough , if not then enlarge or file up and down to give you the required tolerance
Old 26th November 2012, 10:53 AM
All the wobble, as its been described, is taken up by the push rod, as its end is round where it goes into the master cylinder. This allows for off centre movement. Reaming out the pedal hole is just going to add slack to the system. My whole setup is as the book and it works great.
