Old 25th May 2010, 08:01 PM
Default Anyone got an AceWell?
I just bought an unused 3853 for £30 . I no it's not ideal but for that money I am hoping it will do the job.
Anyone else with an Acewell?
What's the best way to fit the speed sensor?
Old 25th May 2010, 08:11 PM
Tatey's Avatar
Tatey Tatey is offline
Where did you manage to find a 3853 for £30?!
Old 25th May 2010, 08:16 PM
Well you have to factor in postage too. Unfortunatly it does come with the loom as well so I won't be able to make up my own custom fittings..
Adding postage, it actually costing £34.
The box is a bit battered though.
Old 25th May 2010, 08:19 PM
you lot are trying to beat my bargaining skills
Nice purchase there TT,
Tho i have no idea how the Acewell is set up so can,t comment on the speed sensor fixing.
Old 25th May 2010, 08:22 PM
HAHA see other "Inbox" Post..
Old 25th May 2010, 08:23 PM
whats that saying???????
"De ja vue"
Old 25th May 2010, 08:37 PM
Have you ever watched Red Dwarf... "May be it is De Ja Vue, it sounds like it"
Old 25th May 2010, 10:30 PM
TSM Locost's Avatar
Hi TT, i have an acewell 3250, speedo and tacho are accurate. temp not far out but fuel gauge bit iffy. My sensor is mounted on the back of the g/box and magnet on the front U/J flange. if you need any info Google acewell 3853 and you will find all you need inc wiring diagram, looks the same as mine.
Be Lucky, Mike.
Old 26th May 2010, 07:33 PM
Coozer's Avatar
Coozer Coozer is offline
As above my Acewell has the speedo senor hanging off the back oft he gearbox, secured on a bracket through the back hole on the gearstick surround. Magnet is glued to the prop fork that comes out the back of the box.
LG,
MNR Vortx Build Diary
www.mymnrvortx.blogspot.com/
Old 26th May 2010, 10:26 PM
have done the same on my koso
