Old 28th May 2010, 09:45 AM
Smile One for TT perhaps
As some of you know, I am fitting a 1.8 Zetec engine in my build.
Just for the challenge I would like to get it up & running by using the stock Ford EEC IV ECU
If all goes pear shaped, I do have both MJ & MS at my disposal & ready to go
Anyhow, to the point of this thread
Does anyone know the size of the Zetecs Fuel pump relay & will it fit into one of these relay holders ??
CBS Relay holder
I don't want to use the Sierras fuse box due to the sheer bulk of the thing.
Already sorted a nice fuse holder & would like to keep my relays tidy & all in the same place
The flasher relay will be too big but that can live under the steering column shroud as it did on the Sierra
Kicking myself that I did not give the fuel pump relay a thought when I removed the engine from the Escort donor
Old 28th May 2010, 12:36 PM
David_17's Avatar
David_17 David_17 is offline
My zetec is running on a standard BLOB ecu (non PATS), using a fiesta wiring loom.
I used a 40amp relay for the fuel pump and another one for the ignition.
Old 28th May 2010, 12:51 PM
Thank's David
Are the relays that you are using just the standard size 40a units.
Just wasn't sure wether the Pump relay was an exotic one & bulkier than usual
That was my thinking behind the CBS relay holder Ignition, fuel pump, rad fan & lights.
That would take care of all the relays I would need & will keep things nice and tidy
Old 28th May 2010, 12:53 PM
David_17's Avatar
Just a standard 40amp one off ebay i got.
Just a side note.. the signal from the ecu to the fuel pump relay is the earth. (it switches the earth to control the relay, instead of the 12v+)
Old 28th May 2010, 02:06 PM
Cheer's for the heads up on that one David
That one would have almost certainly caught me out
Just need to get back into the workshop & get the engine fitted back in
Old 28th May 2010, 03:24 PM
drury318 drury318 is offline
And just to make your day Ronnie, the flasher unit can be replaced with a short one from an Escort etc to match the other relays, no difference at all!
Dennis.
Old 28th May 2010, 04:26 PM
Dennis.
I knew that
It'll be nice to keep them all in the same place.
Thanks for that Dennis
