Old 29th May 2010, 12:52 AM
Tim Tim is offline
Default Drive Shaft
Hi Guys
My donor car was a sierra 1.8cvh,J plate type9 g/box estate car (great I thought) the only thing is the one drive shaft is to long and the other is a tight fit.
Does the hatchback model (saloon) have shorter same length shafts.
TIM
Old 29th May 2010, 01:07 AM
drury318 drury318 is offline
Hi Tim, it doesn`t matter if its a saloon or estate they`re all the same.
The first edition of the book had shorter rear wishbones by about 10mm which required the driveshafts to be modified I believe, but later editions have been altered to allow you to use the driveshafts as they are. If you do a search on here you may find the details.
When I first fitted my driveshafts they were very tight, but after they have had weight on them they sort of get pushed past where they are used to being in their old grease. Might be an idea to strip the cv joints and wash them out/repack them though as this will help. I remember thinking I had made a huge mistake somewhere and my driveshafts were never going to fit but they did, and very well in the end.
Dennis.
Old 26th June 2010, 01:21 AM
Tim Tim is offline
sorry taken so long getting back to forum
It turns out the inner c.v joint was semi seized it would only move 3/4 of full movement. (is it me or is drive shafts for a sierra like rocking horse poo??)
