Old 29th May 2010, 08:50 PM
Headshot Headshot is offline
Default CVH tubo Q
If I go CVH 1.8 route, can I chuck on RS turbo bits later?
Failed builder
Old 29th May 2010, 09:04 PM
not really,
the turbo parts you are thinking about come from the RS1600 turbo cvh engine which is not the same as the 1.8cvh engine.
Although, the exhaust manifold from the turbo engine fits with a little bit of "fettling", thats what i have done as it creates a better exit point from the exhaust manifold compared to the original cvh manifold.
Old 29th May 2010, 09:19 PM
ahhhh thats one thing at least
Failed builder
Old 30th May 2010, 06:02 AM
snapper snapper is offline
Another point to consider is that turbo engines tend to have low static compression, usually about 8 to 1, so you would need to lower the 1.8s compression or seriously reduce boost.
Cometic do special thick gaskets which is cheaper than changing pistons and safer than using two gaskets or a decompression plate.
Old 30th May 2010, 10:44 AM
Big Vern Big Vern is offline
Putting the Turbo & manifold on anything other than the RS1600t engine creates a whole heap of problems for limited extra performance
From memory, the Turbo was only around 150bhp and you can get a healthy 160bhp from a Zetec.
You'll need to change to forged ally low comp. pistons and I don't even know if anyone makes any to suit.....but for the RSt they're about £190 EACH
You could use a decompression plate but they're notorious for leaking and you'll still need stronger pistons anyway.
Just use the CVH to get through the IVA then switch to the Zetec afterwards like spud did. You can always sell the CVH to the next roadster builder....
HTH BV
Old 30th May 2010, 01:55 PM
Cheers guys, Binned the turbo idea, cheers for the pointers
Failed builder
Old 2nd June 2010, 08:28 PM
james3004's Avatar
the standard escort rs turbo was just under 130bhp, i'm personaly using a 1.8 ZVH turbo, cos that's what i have lying around
--- James ---
IVA passed 20 June 2017
Flickr Album
