Old 2nd June 2010, 08:33 PM
james3004's Avatar
Default What Thrust Bearing?
This has probably been covered before...
I'm using a 1.8 zetec bottom end, and mt75 box. I know i can use a 1.8 zetec clutch, but what thrust bearing do i use??
--- James ---
IVA passed 20 June 2017
Flickr Album
Old 2nd June 2010, 08:53 PM
Big Vern Big Vern is offline
The only one I know of is the westfield special but they're very touchy about selling to non westfield owners. Other option is to mod the release arm to move the release BRG closer to the clutch cover but be careful you don't run out of travel on the first motion shaft cover!
HTH BV.
Old 2nd June 2010, 09:24 PM
Don't most people use a CT133 from Quinton Hazell? I used a Capri release bearing on my build to make up the slack between the gearbox and clutch.
Old 2nd June 2010, 09:35 PM
james3004's Avatar
http://www.westfield-sportscars.co.uk/shop/product.asp?numRecordPosition=7&P_ID=254&strPageHi story=cat&strKeywords=&SearchFor=&PT_ID=77
£61!!!
is that the only option?
--- James ---
Flickr Album
Old 3rd June 2010, 12:53 AM
What about trying Burton power or Raceline ?
Old 3rd June 2010, 06:42 AM
snapper snapper is offline
I got the ECB 113 from Burtons, it uses a carrier that is 8mm thicker
Old 3rd June 2010, 10:34 AM
CT 133 is the one to use for type 9 box though there has been issues even with this combo.
THe burton one has an 8mm extension for use with racing clutches but I think you need more than 8mm with the Zetec/MT75 combo.
TT will probably know what combo works
Old 3rd June 2010, 02:00 PM
Have a read of this thread, 3rd post down, from Locost builders:
http://www.locostbuilders.co.uk/view....php?tid=81537
It gives you everything necessary for Zetec to Type 9 or MT-75, and as Vern states it looks like you need to obtain the modified release bearing for the MT-75 otherwise the CCT133 will work with the Type 9 box.
I have a type 9 with a 2.0l Zetec and combined they work great together, as i'm going to remind myself of tonight.....
All the Best....AndyH
Old 4th June 2010, 02:49 PM
james3004's Avatar
Quote: "The Zetec engine will need to be fitted with a spigot bearing in the centre of the flywheel to accommodate the input shaft of the gearbox. It's not required by the original Mondeo / Escort gearbox . It is a Standard Ford part Finis No:1596468 "
What is a spigot bearing?
--- James ---
Flickr Album
Old 4th June 2010, 03:51 PM
The spigot brg fits in the back of the crankshaft and the front of the gbox first motion shaft rides in it.
It supports the first motion shaft to stop it flapping around like a d%*k in a shirt sleeve!
The westfield release brg is the one you'll need and good luck with getting hold of one as Westfield are pretty fiesty about selling to non westfield owners.
BV.
