Old 4th June 2010, 06:39 PM
rapidtornado's Avatar
Exclamation My knuckles are raw!!! HELP
Made the absolute school boy error today used a size35 torx bit instead of a size 40 by mistake, wondered why the bolt wasn't giving purchase and yes you guessed it rounded the begger!!!
And of course is in a real tight spot (EFI inlet manifold bolt under the throttle body) any suggestion before I put my hammer through the front wing?
Matt
Old 4th June 2010, 06:43 PM
gingea1pom's Avatar
Matt,
Knee jerk answer could you weld a bolt onto the rounded torx bolt.
Tell me I am not talking out of my ar**
Cheers Ginge
Build Pictures
Old 4th June 2010, 06:47 PM
Unhappy
can't get the head of the welder in there
Old 4th June 2010, 08:56 PM
Angry
Just when you think you are getting somewhere..... managed to drill out the centre of the bolt wedged a size 35 torx into the hole, about 5 mm deep, put the wrench on, good purchase.... happy days no ping! torx bit has snapped off in the centre of the bolt, now I got a hardened bit wedged in an already rounded out slot, I think it's fubar'd
time to sit and think!!!!!
Old 6th June 2010, 06:57 PM
Johnnybizzle Johnnybizzle is offline
Bugger,
Time to carefully drill out and re thread i think, my engine has half dozen different threads where over the years a few people has tinkered with it.
Old 8th June 2010, 10:11 PM
My friends the beer is flowing tonight!!!
After 5 1/2 hours of attacking this fricken bolt I managed to get a slot through the middle, butcher up one of my old wood chisels, file two flats on the handle then carefully unscrew the bolt, this sounds a bit basic but it took 1 hour of hacksawing just to get the slot in it due to access
My car will now officially be called 'the bolt'!!! the fun bit starts now working on a new EFI plenum design to bolt back up to the car
Happy days!!!
rapid
Old 8th June 2010, 10:17 PM
gingea1pom's Avatar
Well done that man
Build Pictures
Old 8th June 2010, 10:33 PM
Headshot Headshot is offline
Been there with plumbing before, every time your hacksaw slips off you feel like lying on the floor and crying
Failed builder
Old 9th June 2010, 05:27 AM
Hoybi's Avatar
Hoybi Hoybi is offline
if you can reach it, grind a slot with a Dremel kind of tool, so you can use a scredriver
Eddy
www.alfaprojects.be
