Old 6th June 2010, 02:15 PM
bobbyh bobbyh is offline
Default Rear PDC of the wheel bolts.
Hi,
quick question what is he PDC of the rear wheel bolts??
thanks
Old 6th June 2010, 02:38 PM
David_17's Avatar
David_17 David_17 is offline
4X108 iirc
Old 6th June 2010, 02:45 PM
is that the same on all sierras? thanks
Old 6th June 2010, 02:50 PM
David_17's Avatar
Think it's the same on most fords (appart from the new ones). But the sierra pickups (P100) have 5 stud hubs.
Old 6th June 2010, 02:54 PM
Thanks for the help
Old 6th June 2010, 02:59 PM
Peugeot pcd is the same for the four stud variety and possibly Citroen.
Old 6th June 2010, 03:40 PM
Definately citroen also.
Old 6th June 2010, 04:05 PM
And Saab 4 Stud on the older models.
Offset on PAS group cars is usually only 15mm where most FWD/Sierra/Granada fords is closer to 35mm. Old fords usually were around 15 though.
Old 6th June 2010, 05:20 PM
Audi also used 4x108 PCD. The centre bore is smaller though, 57 mm on Audi, 63.4 on Ford.
Old 6th June 2010, 07:07 PM
is it not 5x108 on Audi?
Center bore is defo different as I have Hubcentric rings to fit my Granada 5 studs to My VW based Galaxy.
