Old 6th June 2010, 08:38 PM
Default Does this look right to you?
This looks like its for a FWD application to me, or am I being thick?
Adrian
http://cgi.ebay.co.uk/FORD-1-8-2-0-Z...item41501ddc69
Old 6th June 2010, 08:43 PM
Davey's Avatar
Davey Davey is offline
Yup! Defo a FWD fanimold. Could possibly be altered/adapted to suit a RWD layout but looks like more work than making one from scratch.
D.
Old 6th June 2010, 08:45 PM
I thought most FWD Fords exhausted at the front of the engine and curved back under..
That looks uselsess in any application.
Old 6th June 2010, 08:56 PM
Davey's Avatar
good point TT, early 1.6 Zetecs had exhaust at front as do the 1.8 and 2.0 litre units but the later 1.25, 1.4 and 1.6 S and SE versions (alloy block built in conjunction with one of the Jap bike companies I think) had inlet at front and exhaust to the rear. A bit of a conundrum .
D.
Old 6th June 2010, 09:19 PM
Probably Yamahhhha As they did a few engines with ford
Old 8th June 2010, 10:18 PM
Yep, AFAIK Yamaha helped Ford during the development of the Zeta (Zetec E) engine, and Sigma (Zetec S) is a Yamaha design throughout.
Old 9th June 2010, 09:39 AM
Are we looking at the same item.......
Wish i'd seen this a year ago, it looks ideal for the roadster Zetec exiting straight out the side of the engine bay - height and offset from engine looks about right to. And for £75 in s/s is bloody good value to. Anyone fitting Zetec then grab his hand off.
But yes you're right the stock manifolds exit from the front and tuck underneath. The stock Focus ST170 is a good full flow exhaust to use with the bottom section 2-1 shortened and turned to exit to the side of the roadster. You won't get one that cheap though.
Regards....AndyH
Forgot to say, will also fit a cvh to.....
Old 9th June 2010, 09:54 AM
Coozer's Avatar
Coozer Coozer is offline
That ebay jobbie on a zetec will indeed punch straight out the side of a roadster. Although it looks a bit long to be honest, may stick out to far.
I may dig that ST manifold out and see how much its worth...
Actually, just found this....
http://cgi.ebay.co.uk/FORD-FOCUS-ST1...item3a5b919cce
MNR Vortx Build Diary
www.mymnrvortx.blogspot.com/
Old 9th June 2010, 10:00 AM
Yes it maybe close Steve, just measured and you have 320mm from the centre of the flange to the side panel just where you would need to fit a bend.
Maybe worth asking the question for distance to outlet.
AndyH
Old 9th June 2010, 07:11 PM
Big Vern Big Vern is offline
Looks like Zetec E to me judging by the bolt patern.
Guess it's designed to come out the side panel then turn down the side to the muffler.
BV.
