Old 8th June 2010, 09:08 PM
les g les g is offline
Default for spud re dash
Spud69
have you done anything with your new dash yet
i was messin with mine at the weekend and the pick-up cable seems way way to short
it wont reach the diff bolts no chance
i am gonna mail them later and see if they do an extension cable or find out if its ok to just chop it and lengthen it
cheers les g
Old 9th June 2010, 09:24 AM
Hello Les,
Is yours the 10k rpm Roxo dash as mine fitted no problem, used the speedo sensor, oil and water temp sender and all plugged in and working within half a day. The speedo sensor reached the diff flange no problem, route was behind the dash and straight into the bottom of the tranny tunnel to a new bracket on the rear prop uj where it reads 8 clicks per revolution.
Attached some pics for you Les.
Anything else just gis a shout Les.....AndyH
