Old 13th June 2010, 10:03 PM
will_08 will_08 is offline
Default About to lose shell?!?
Right finally stripped my donor sierra, cut the shell into 5 manageable chunks.
ground the ID in the floor pan, got the Vin plate etc
Is there anything else that could be on the shell that is often overlooked. specifically i thought i saw in the book something about removing gearbox mounts from the shell?
Any suggestions are much appreciated
Cheers Will
