Old 14th June 2010, 04:45 PM
Default Do you think this is a fair price
Hi all, been down to one of the local breakers yards this afternoon where I found a D.O.H.C. in J-reg sierra, they want £230 for the engine, gearbox and back axel, all removed redy for collection. Any thoughts on this as a price
Thanks
Old 14th June 2010, 05:07 PM
It's not really Arfon but then people are getting wise that we need these cars and there aren't too many about. If its been scrapped also it means you won't get your age related plate either, if you're that bothered about it. Scrapyards won't let you remove parts yourself now either, H&S bull - but the new government's going to sort that one out
You could try and haggle for the full donor bits you need ie, brakes, front uprights, master cylinder, loom, handbrake, prop, header tank, exhaust manifold and i'm sure somebody else with add. Then again they are bound to want more money for it.
Good Luck...AndyH
Old 14th June 2010, 05:11 PM
Depends on mileage condition etc
Dont suppose it seems too bad if you really havnt got space to strip a donor, remember you will want the master cylinder, wiring loom, front uprights, front calipers and the steering column too though
Buying from different sources costs more and also rules out an age related plate
If you have the space i would recommend waiting for a suitable donor and getting everything you need in one go
Some people buy complete running cars for that sort of money
Spud beat me to it!
Last edited by mark : 14th June 2010 at 05:58 PM. Reason: question already answered before i finished my slow typed version!
Old 14th June 2010, 05:35 PM
I'm quite lucky in the fact that we have a few breakers yards local so maybe I could try and play one off against the other. Will gain some room tomorrow for a donor car as once the escort passes the MOT a neighbour wants to buy it so freing up some room and cash
Old 14th June 2010, 08:13 PM
bigheppy bigheppy is offline
Do a search for UPULLIT they let you buy a car from them, they have to remove the engine and gearbox for you, then you have 7 hours to remove everything else you want.
http://www.u-pull-it.co.uk/info.html?view=pickACar
Try this link
No v5 tho
Old 14th June 2010, 08:18 PM
Davey's Avatar
Davey Davey is offline
£230 for engine gearbox and axle doesn't sound too extreme to me, especially if they remove it for you. A half decent second hand engine is going to set you back a ton at least, gearbox similar so I'd say you're getting the axle cheap. Don't forget the breakers are there to make money. I've just lashed out £330 for two gearboxes and a second hand clutch for my build and I've got to build a hybrid out of the two boxes. To put that into perspective I only paid £361 for my donor car which still had 8 months MOT on it.
D.
Old 14th June 2010, 08:28 PM
DStanley1809's Avatar
DStanley1809 DStanley1809 is offline
My whole J-reg DOHC donor cost £275 but I do have to store it and remove all the bits myself. As Mark said, you will also need other parts too.
I'm a tight fisted git so wouldn't want to pay that knowing I still need more bits and that a whole car doesn't cost much more
I was also able to see and hear it running so I know the engine works.
Old 14th June 2010, 08:35 PM
Headshot Headshot is offline
I got an offer from a new company that recycles cars as an education project,
£475 delivered for a project pack, ie: engine/box/loom/hubs/axle/steering column/master cylinder/ and any switchgear I want from their box of tricks.
all cleaned.
This may be the way I have to go as I have no where to strip a donor
Failed builder
Old 14th June 2010, 08:37 PM
David_17's Avatar
David_17 David_17 is offline
all cleaned.
Hmmm... that company sounds like the same one that i got mine from.
I paid less than that, got everything but the engine for £265
Old 14th June 2010, 08:50 PM
Yeah, think the engine alone was around £200
Failed builder
