Old 17th June 2010, 10:20 PM
Default anyone replaced type 9 input shaft bearings.
Has anyone erplaced the input shaft bearing on a type 9? and the needles to the mainshaft?
Any coments on ease?
Old 17th June 2010, 10:28 PM
David_17's Avatar
David_17 David_17 is offline
I haven't, although i do plan on doing it at some point if anyone has any tips
Old 18th June 2010, 10:29 AM
Davey's Avatar
Davey Davey is offline
I haven't done one ofr a good few years but if you have done gearbox work before its not too difficult. A tip for the mainshaft nose bearing needle rollers is to "fix" them in place with grease during assembly. If you google search you should be able to find a PDF manual for overhauling the box, I did for the MT75.
D.
Old 19th June 2010, 04:30 PM
First motion shaft is no big problem just be aware of the bearing on the inside of the mainshaft and the seal in the tube,there is a dummy shaft used to replace the rollers in the lay shaft but as said it is possible to "stick them in".
The Bullet box has these replaced with a bush for more power input.
