Old 25th June 2010, 09:05 PM
Peter-C Peter-C is offline
Default rear brkae pipe tee piece
Hi,
How do you fix the tee piece to the rear frame ? Do you have to use a nut and bolt or can you tap a 6mm hole and just use a bolt ? With the latter there isn't a lot of thread. Just had a thought, why not weld a bracket onto the frame.
Peter
Old 25th June 2010, 09:09 PM
Enoch Enoch is offline
I welded a small bracket to the frame. You must have a locking device on the nut / bolt, I used a nyloc. If you went the rivnut route the IVA man my query it.
Enoch
Old 25th June 2010, 09:25 PM
Cheers Enoch,
A bracket it is.
Old 26th June 2010, 10:18 PM
If you have a look at my build diary - www.deepfolly.co.uk you can see how I fitted mine. I did my flexible pipe brackets different too as it made the hoses easier to route.
Enoch
