Old 29th June 2010, 09:44 AM
davidimurray's Avatar
Default Rivnut spacing
Floor and seatback panels are now made up so I'm moving onto the tunnel. I'm planning on making the side/top removable by fitting them with rivnuts. Anyone have any advice on what spacing to fit them at? I was thinking at about 150-200mm centres.
Old 29th June 2010, 11:12 AM
i would put the ali panel in place then use some brown paper tape either side and on the left hand side mark the spacing at 150mm apart and on the right hand side mark them at 200mm apart and see which you prefer/looks better.
