Old 4th July 2010, 04:29 PM
Johnnybizzle Johnnybizzle is offline
Default Mini LED Side repeaters
I have seen some mini LED side repeater form Kit parts Direct which i can mount in my on the outside of the front wings will this comply with IVA rules as a Side repeater or will i need another 1 on the scuttle???
Also got some wing mounted iridium Lens Indicators for the front which Are E9, the reason for at the wing mounting is my nose cone and bonnet are together and if indicators mounted to nose cone i would have to un plug and to be able to take to front end of the car off.
any helpful advice from you guys in the kno or who have had your IVA would be great because a want to get these ordered up for next week end to finish my car (eager Beaver)
Regards Jon
Old 4th July 2010, 09:17 PM
drury318 drury318 is offline
Hi, I fitted some small led lights in the front edge of the REAR wings, they were from Boltonbits, on ebay, but I am sure they are the same as the ones you are talking about, only cheaper!.
I think you can put them in the front wings so long as they meet the requirements in the IVA manual, the main thing is they have to be visible from the rear which is why the scuttle is not such a good place for them, though not impossible. Wiring is also a pain in the front wings as it has to be flexible & hidden away.
Have a look in my photolink, mine has passed IVA like this by the way.
Dennis.
Old 5th July 2010, 09:36 PM
Thanks for the reply Dennis will probably do the same as you, how did u fasten the cable to the underside of the arch... Adhesive?
Regards Jon
Old 5th July 2010, 10:39 PM
Hi, yes I used Tigerseal adhesive, works a treat!
