Hay all i got a 10mm error here
Right its in the height of U1 and U2. The distance between the top of br1 and tr1 is 305mm. But if you work out the height of U1 using the measurements in the back of the book it comes out at 315. With a hypotenuse of 345mm and an angle of 24' gives a height of 315.Anyone else found this? Last edited by Eternal : 5th July 2010 at 10:29 AM. |
Can anyone confirm the correct size for this part so i can continue tomorrow?
Good night all |
I haven,t got the book at home with me,
but do you mean U1 & U2 ? If you do mean U3 , i,ll check my book in the morning What is more critical is the distance between U1 & U2 where they sit on top of BR7, Tho are you altering those dimensions for your engine choice? sorry can,t be more help till the morning cheers andy |
here is a pic from gingea1pom's build showing what i mean.
My book shows a 24 degree cut and a side lenth of 345mm this gives a hight of 315mm and wont fit in the 305mm gap. I have a revised book that has all the ammendments in so maby this is a new mistake? |
As I haven,t got the book with me,
The distance between U1 & U2 on the top face of BR7 if i remember correctly is 261mm ( i think thats correct, but check against the book diagram please), Its a long time ago that I built my own chassis but don,t recall any problems fitting U1 & U2 , & yes my chassis is 305mm in overall height too... I was never the best at maths so you now have me wishing I had my book with me cheers andy Last edited by HandyAndy : 5th July 2010 at 12:43 AM. |
yeah 261 is right for the distance between the two uprights got that bit marked out ok. Its just when i got around to putting them in they were 10mm too high lol. I will do a scan of my book tomorrow morning just to show im not mad or anything
This book is the 2008 reprint. ISBN 9781844253913 |
I think you forgot to substract sin(24°) * 25 from the length to get to the oblique end. When you do, the discrepancy is just 0.88 mm:
Code:
>>> (345 - (sin(24./180*pi) * 25)) * cos(24./180*pi) 305.88387256822983
Albert Haynes Roadster FAQ | Haynes Builder Locations Gallery, build thread in Lithuanian / via Google Translate. |
damn thats total length lol urrgh
Thanks for pointing that out lol ![]() problem solved lol and thanks. |
I,ve just arrived at where I,m building my car,...
I,ve just measured my own chassis as best as I could ( difficult to get the steel ruler into position as there is so much other stuff in the engine bay) The length of U2 from the point of where it sits on top of BR7 closest to the center line of BR7 to where U2 meets the outer edge of TR2 is 320mm, Tho like I say, its not easy to get the steel ruler in there , does this help at all? oops, too slow.....nice one Alga , glad it came good in the end cheers andy Last edited by HandyAndy : 5th July 2010 at 11:38 AM. Reason: additional text |
| Thread Tools | |
| Display Modes | |
