Old 4th July 2010, 07:22 PM
Johnnybizzle Johnnybizzle is offline
Default Digi Speedo Magnets
Hi Guys,
Finished mounting my digi dash and speedo pick up ive now got the task of sticking magnets in place to the sprocket adaptor flange, got six magnets in the kit tried all six but way out on calibration, guna keep trying with fewer magnets till its right, does any 1 know how many to use and what spacings (equally i assume) to save me some time????
Regards jono
Old 4th July 2010, 08:03 PM
Coozer's Avatar
Coozer Coozer is offline
One magnet glued to the prop yoke with araldite. Two may be better and the gap as close as you can.
MNR Vortx Build Diary
www.mymnrvortx.blogspot.com/
Old 5th July 2010, 09:43 PM
thanks for the reply will have a go later this week mite use the sat nav to get a good calibration
regards Jon
Old 10th July 2010, 04:29 PM
if you use a thing called a proximity switch (rs online) you can switch of almost any metal part
i have seen theaes used on motorbike in disc bolts to run speedo
come in loads of diffrent sizes and can be made real small sme are like a 1 inch m4 stud with a wire coming out
thay do need a 6-24v dc supply but v low ampage
