Old 12th July 2010, 04:03 PM
Eternal Eternal is offline
Default Cp10 problems.
Pos a book error. It says to align cp10 with the back of sb4. Now the front of sb4 is 269mm long and cp10 is 268mm. But the back of sb14 goes down by 17 degrees so cp10 won't fit. Any idea what I should do?
Skyline Roadster
Old 12th July 2010, 04:12 PM
Twin's Avatar
Twin Twin is offline
Wait for HandyAndy!!!
Twin
CSF £857.19
Twins Roadster
Old 12th July 2010, 04:50 PM
dogwood's Avatar
dogwood dogwood is offline
I can't help you with the measurements as I don't have the book here.
What I can tell you is CP10 must fit flush with the back of SB4
Because that's where the diff bracket bolts to.
David.
Old 12th July 2010, 05:01 PM
As David has said, CP10 must align flush with the rear face of SB4,s as the CP10.s are the main chassis plates for the diff hangers,
As you have found , due to the angle of SB4,s & the length of CP10,s "it doesn,t fit"............
You are not the first builder to have come across this & others in the past, including me have removed a little off the CP10 to get it to fit "snugly", but ensuring it fits on the rearward face of SB4 to aid the flush fitting of the diff hangers.
Don,t forget the holes in CP10 are spaced differently & so must be placed the correct way up.
hope this helps,
Old 12th July 2010, 05:04 PM
ahh i see cool well i will make sure i take the same off each one so i dont have a twisted diff. ohhh crap did not even see that the holes were different. Nice one
Skyline Roadster
Old 6th August 2010, 07:27 PM
to get cp10 to fit scribe a line 25 mm from the bottom (hole center) then do the same on the back face of the 2 vertical tubes of the seat back trim the top end to suit with the two scribed lines in line
i made them 4mm shorter all removed from the top end of cp10 to get the hole center 25mm above the base tube as shownin the diagram
hope that clears it up
Old 7th August 2010, 12:09 PM
KenK KenK is offline
Oh b.....cks, just checked, i have put one the wrong way up!! Which is the correct way please before i get Mr Angry Grinder out!
Ken
Old 7th August 2010, 12:52 PM
25mm offset hole at the bottom.
p45 section A-A
Old 7th August 2010, 01:30 PM
Smile
Cheers mate, grinder successfully deployed!
Old 7th August 2010, 11:19 PM
les g les g is offline
why not just redrill the holes in the right place
you could also weld up the old holes if you need too
cheers les g
