Old 15th July 2010, 06:44 PM
Pavel Pavel is offline
Default Rocker pivots
All,
I welcome any ideas or suggestions on what the best way to pivot the rockers for inboard suspension on a locost are.
It needs to be a straightforward mount, preferably using the same brackets to chassis as the suspension (i.e. those that accept a 44mm crush tube), and be low cost - therefore no ball bearings pressed into either side of the rocker, pivoting on some super special shaft.
The idea of standard suspension polybushes has been poo-poo'd as not being able to withstand the load.
Current front-runner is to use a carefully machined nylon bushing to ride on a standard 44mm crush tube, and pressed into the rocker.
If anybody has any other thoughts or suggestions, I could really do with some brainstorming.
Cheers,
Pavel
Old 15th July 2010, 07:22 PM
3GE Components's Avatar
Use needle roller bearings with igus washers. This will be more than capable.
Kind regards
John
Old 15th July 2010, 07:49 PM
Hi John, do you have specific dimensions/part numbers I can look at? Did you use an off-the shelf shaft?
Cheers,
pavs
Old 15th July 2010, 09:17 PM
Pressed in rose joint and suitable spacers ?
