Old 17th July 2010, 07:03 PM
jasongray5's Avatar
Default Zetec flywheel position?
afternoon all.
Problem.
some bright spark rubbed off the markings i made from my flywheel to engine, and I now have a possible of 6 ways that it can bolt back up to then engine?
Its a 1.8 blacktop and standard flywheel?
Has anyone got any bright ideas?
Chheers Jas
Old 17th July 2010, 07:27 PM
Does the zetec blacktop have the Crank position pickup wheel on the fly?
If so, get cylinder 1 at TDC and then the -1 on the trigger lined up with where the sensor would be.
If not, fit it any way and forget about it, your very very unlikly to notice any difference at all.
Old 17th July 2010, 08:06 PM
snapper snapper is offline
Worth checking and I stand to be corrected but with the Megajolt the missing tooth is 90 degs before top dead center
Old 17th July 2010, 09:10 PM
David_17's Avatar
David_17 David_17 is offline
iirc one of the bolt holes is slightly off set so it will only fit one way.
*updated 7/6/11*
Old 17th July 2010, 09:35 PM
Not tried it on a Zetec, but that is indeed the usual way.
Old 17th July 2010, 10:00 PM
Not so on pinto, cvh, cologns , dohc's that I have worked on. And the CVH fly is used on the zetec conversion.
Old 18th July 2010, 10:32 AM
Big Vern Big Vern is offline
The DOHC, CVH and ZETEC flywheels I have all have an offset hole so there MUSt be an offset hole in the crank.
You usually find this out when you've toqued up five of the bolts and the last one won't go in DOH!
Try fitting the flywheel and nipping upo the bolts.
I will check later on my old TIS to see if the official manual can Identify a mark or reference.
BV.
Old 18th July 2010, 11:08 AM
No Mention of it in TIS, just undo and do up 6 bolts.
Old 18th July 2010, 06:52 PM
Holes are definately offset - the flywheel will only go on one way.
Adrian
Old 18th July 2010, 10:51 PM
Coozer's Avatar
Coozer Coozer is offline
Yep, as said there is only one way it fits.
Holes are offset to ensure the timing of the 36 -1 is always correct.
MNR Vortx Build Diary
www.mymnrvortx.blogspot.com/
