Old 28th July 2010, 09:05 PM
tkpm tkpm is offline
Default Fixing Nose Cone
Hi all,
Does anyone have a picture of how there nose cone is fixed to the chassis (from the bonnet end to the front) if that makes sense, as mine seems to not much of a lip to put fixings through.
Terry
Old 29th July 2010, 10:08 AM
Its only a small lip that sits on the chassis inside the nose but there is still room for a couple of m6 bolts on each side rivnutted into the chassis, i cut some big washers almost in half and used these to spread the load a little, i also put another 3 underneath the bottom at the front, again with big washers on them.
Old 29th July 2010, 09:15 PM
DaddyA's Avatar
DaddyA DaddyA is offline
Hi Terry,
I had the same problem. Not enough on mine for a bolt one side so had to adapt and overcome as they say.
I'll email you some photos.
http://i641.photobucket.com/albums/u...y/DSCN3877.jpg
http://i641.photobucket.com/albums/u...y/DSCN3878.jpg
Couldn't email, too big so here is some links - hopefully of some help.
Daz...
Old 29th July 2010, 11:41 PM
Thanks Daz,
Those pictures are just what i needed
Terry
Old 30th July 2010, 09:01 AM
I used m5's on mine with speaker washes top and bottom
Old 30th July 2010, 10:09 AM
I'm afraid the mold for the nose cone doesn't allow for much a flange to be formed for fixing of the nose cone. Going to have a go at modifying the mold soon to allow for better fixing.
It does fix on okay at the moment, if not a little awkward.
Regards.....AndyH
Old 30th July 2010, 03:33 PM
fabbyglass
Fix it at the bottom then use a dzeus fastner where it meets the bonnet so it holds both the nose cone and the bonnet......simples!
Andy, adding a bit to the flange is easy done if you feel the need..clamp some wood to the flange while it's off the nose with enough to give a bigger flange then simply gel and 'glass it ....resulting in a wider flange
Any news on the single seater beastie? I made me own but the engine may be a problem oh and will fry the IVA bods brains...
File Type: jpg 1st composite kayak out of the mould.JPG (29.7 KB, 120 views)
Old 30th July 2010, 04:24 PM
Kayak's is looking good Mark, that is the plan with the nose - some pvc trim
Single seater is done to Mark, Chris has trial fitted it and reports that all is hunky dorey...
AndyH
Old 30th July 2010, 04:56 PM
fabbyglass
Cool when can I see a picture of the beastie?
Old 30th July 2010, 05:05 PM
Hopefully after Chris had got back from his hols we can tease some pics out of him....
