Old 28th July 2010, 09:49 PM
Default Starter motor woes
Hope someone can help me here. I've got an LRS707 starter as recommended by several people. But when I offer the starter up to the engine the pinion gear doesn't have enough throw to meet the ring gear. It's a silvertop zetec with a 1.8 flywheel, and a type 9 gearbox. The measurement from mating face of the starter/bellhousing to edge of ring gear is 35mm, and the ring gear is around 5mm thick, so I reckon I need a starter that will put the pinion gear around 40mm from the mating face when it's thrown out. Hope that makes sense, and if anyone has any ideas, I'd really appreciate them, as I'm having one of those burn the ba?'@&d moments with the car!!!
Adrian
Old 28th July 2010, 11:04 PM
drury318 drury318 is offline
Adrian, I can`t help with part nos etc but I have a 1.8 Zetec/type 9 combo & I used a 1.8 CVH starter which went on with only minor mods to the sump webbing. Hope this helps, Dennis.
