Old 6th August 2010, 09:28 AM
Josh's Avatar
Josh Josh is offline
Default Painting wishbones
Hi all
I'm about to start my big chassis paint next week after the welding is finially finished this weekend . For now though I thought I'd start painting my wishbones and a few other bits.
However I've allready pressed my poly bushes and anti-crush tubes into my wishbones, should I take them out before painting?
If so how should I go about pulling the bushes out they were pretty hard to push in to start with!!
Josh
Old 6th August 2010, 11:11 AM
Personally i wouldn't try removing the bushes i would just mask them up good with some electrical tape as is nice and thick and will peel off easily when the paint is dry.
Old 6th August 2010, 11:54 AM
If your bush tubes are still bare metal inside where the bushes locate i would definately take them out before you paint them, they will inevitably get wet one day you will get rust forming inside the tube.
Granted the rust would take years to do any real damage but i wouldnt want signs of rust forming around the end of the tubes on mine after all the time and hard work it takes making them!
I took mine out after they had been fitted and it wasnt that difficult to remove them just be careful with them, i pushed the crush tubes out first then pushed the bushes out from inside rather than prising at them from the outside
If you do paint inside the tubes dont over do it though as your bushes will be even tighter on re-assembly
