Old 8th August 2010, 08:13 PM
Deanno's Avatar
Deanno Deanno is offline
Default Are these Lights ok??
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=220611915114&ssPageNam e=STRK:MEWAX:IT
Old 8th August 2010, 08:29 PM
erm... yes & no..... I,ll explain.
If these lights are fitted into bodywork then yes they are ok,
BUT
If not fitted into bodywork then they won,t pass the radius test on the rear edge of the lamp holder....
What I mean is.. the back lights ...stop/tail & indicators would fit flush into your body work, but where would you fit the front white side lights & front indicators in bodywork on the front of the car?
Also, most ( not all ) modern headlight units come with side lights built in, mine did & only cost £35 for the pair of headlights with side lights built into the headlamp bowl.
Old 8th August 2010, 09:10 PM
I have some WIPAC 95mm rear lights for sale if you're interested, stop\tail and indicators, along with housings, connectors and bulbs if you're interested.
£30 delivered, PM me if you're interested
Adrian
Old 8th August 2010, 09:37 PM
Deanno's Avatar
are they similar to these?
http://cgi.ebay.co.uk/6-REAR-95mm-Lights-Kit-Car-Westfield-Caterham-Locost-/220634723593?cmd=ViewItem&pt=UK_CarsParts_Vehicles _CarParts_SM&hash=item335edab509
Old 8th August 2010, 11:38 PM
That's them! No reverse or fog though, just the four others. Let me know.
Adrian
Old 9th August 2010, 05:53 PM
Deanno's Avatar
are they new?
Old 9th August 2010, 06:35 PM
They are new, but my previous post said they had the black mounting rings, which they don't. You can buy them for £2.50 each from bolt on bits on ebay, or mount the lights directly on the wings.
Hope that helps
Adrian
Old 9th August 2010, 07:45 PM
Deanno's Avatar
I'm going to have to give them a miss at the mo as i now have to build a shelter to build the car as my shed is too small.
Sorry
Dean
