Old 12th August 2010, 06:15 PM
james3004's Avatar
Default Is this in the right place?
Started mounting the engine today just wondering if its in the right place?
--- James ---
IVA passed 20 June 2017
Flickr Album
Old 12th August 2010, 07:48 PM
RAYLEE29's Avatar
RAYLEE29 RAYLEE29 is offline
Hi, if you mean fore and aft then it looks reasonable as for side to side it needs to be central so if it is all well and good that just leaves the height
which needs to be level or slightly up at the front with the output shaft close but not exactly the same height as the diff flange, there needs to be a slight difference in height to stop the prop u/j's from brinneling.
hope it makes sense.
Ray
Total spend so far £1116.08
1ST ALBUM HERE
2ND ALBUM HERE
