Old 17th August 2010, 05:43 PM
Peter-C Peter-C is offline
Default Fuel pipes
Does anyone know if the fuel pipe(s) must be proud of the chassis/body as per the brake pipes or are they allowed to touch ?
Peter
Old 17th August 2010, 06:07 PM
snapper snapper is offline
As long as they are firmly P clipped at the required intervals there will be no problem
Old 17th August 2010, 06:32 PM
Peter
Old 17th August 2010, 07:36 PM
tex tex is offline
ideally they should come into contact with a sharp corner or anything moving or hot
Old 17th August 2010, 07:41 PM
Davey's Avatar
Davey Davey is offline
I suspect this should read
"ideally they should NOT come into contact with a sharp corner or anything moving or hot"
D.
Old 17th August 2010, 08:30 PM
davidimurray's Avatar
Personally, I have kept all my fuel rails away from anything so that they only ever touch the p clips (or hose at the ends ) in the same way you do with brake pipes. My logic behind this was that in use the pipes will vibrate and if they touch anything like the edge of a tube they will start to 'wear' through as they do.
Old 17th August 2010, 08:41 PM
Use copper pipe as much as you can to keep them rigid then where they are close to any projections, eg chassis rails either end of tunnel, sleeve the copper pipe with some of the rubber hose you'll be using at each end. Will do the job fine.
AndyH
Old 17th August 2010, 09:08 PM
Cheers lads
Old 17th August 2010, 11:36 PM
they cant touch regardless of what material they are made from. when do you recall a fuel or brake line touching the chassis on a production car? been there got the t-shirt
the iva rules are pretty simple if you approach them like this. Think would ford, vauxhall, bmw etc do this on one of their cars if the answer is no then it is unlikely to pass. it wont work for everything but its a good rule of tumb to work by.
Old 17th August 2010, 11:54 PM
tkpm tkpm is offline
Can you use brake pipe, for the fuel pipe and what size.
