Old 19th August 2010, 10:12 AM
davidimurray's Avatar
Default Heatshrink for Spade Terminals
Does anyone happen to know what size heatshrink fits over 6.3mm spade terminals? I am planning to use uninsulated terminals then heatshrink over them to insultae them.
Old 19th August 2010, 10:15 AM
You can buy boots. Try someone like vehicle wiring products.
Old 19th August 2010, 10:16 AM
http://www.vehicle-wiring-products.e...ninsblades.php
Old 19th August 2010, 10:29 AM
Personally I'm not a great fan of the boots. I plan to use adhesive lined heatshrink so that once the connection is made, the heatshrink will shrink down and give the wire extra support as well as insulating the terminal.
http://www.vehicle-wiring-products.e...k.php#adhesive
Old 13th October 2010, 02:52 PM
Did you ever find out what size heatshrink as needed?
I like the idea of doing it this way.
Sean
