Old 24th August 2010, 06:06 PM
eSteve's Avatar
eSteve eSteve is offline
Default Lower harness mounts - inspection there of
Do the lower harness mounting have to be visible to the IVA inspector?
If I were to panel the interior of the cockpit the inspector would only see the lower harness bolt going through the panel. He would not be able to verify the integrity of the lower harness mount's weld to the chassis and also the grade of the captive nut the harness bolt screws in to.
Is this a problem?
Would documentry evidence (photos.) of the construction, taken prior to panels being fitted be acceptable evidence for the examiner to be satisfied?
What are your opinions on this or better still has any member IVA'd their roadster with interior cockpit panels?
Regards,
eSteve
Old 24th August 2010, 07:20 PM
He checked mine at iva with a torch from the back near the diff, he could see enough to make him happy.
I did have photos of this part just incase but he didnt want to see them
Old 24th August 2010, 07:58 PM
eSteve's Avatar
Ah, looks like I didn't make my self clear, yes, of course as you say, the inner mounts can be inspected from the trns. tunnel with the transmission tunnel panels in place, but what I meant was if the other mount is panelled in. That is, the mount on the side of the car having an outer panel (the side of the car) and and inner panel (lining the cockpit)? It would not be possible to inspect the mount.
Is this a problem?
Regards,
eSteve
Old 25th August 2010, 08:41 AM
Ahh, sorry i see what you mean now
Yes he made a point of inspecting all of mine thoroughly at my test so personally i would leave them visible until after the test if your panel isnt easily removable
Old 25th August 2010, 12:32 PM
eSteve's Avatar
Thanks for your suggestion Mark, that's a good idea to leave the panels off for IVA, also it will let the inspector see all the welds aswell.
Regards,
eSteve
Old 25th August 2010, 01:34 PM
they accepted the photos of mine as they couldnt see the ones in the tunnel as it was sealed up from underneath.
make sure you weld the bracket on both sides.
Old 25th August 2010, 05:47 PM
eSteve's Avatar
Ah, that's interesting AshG. Nice to have some first hand experience of these matters. Presumably your photos had enough detail to show the 8.8 or 12.9 markings on the nut?
Regards,
eSteve
Old 25th August 2010, 07:44 PM
Steve I could be wrong but in all the years I have worked in the motor trade and trust me it's more than a few, I cannot remember seeing 8.8 or any other on a nut.
Its more the strengh of the bolt @ 8.8 or more and personally my brackets are folded to give more area to weld to.
Old 25th August 2010, 11:27 PM
The metric nuts have something more like |8| stamped on them. It's hard to get nuts worse than grade 8 here.
Old 29th August 2010, 10:20 AM
RAYLEE29's Avatar
RAYLEE29 RAYLEE29 is offline
Ash you say weld the brakets both sides is that cause the iva man says so.
surely if they are welded properly on one side that should be strong enough.
Ray
Total spend so far £1116.08
1ST ALBUM HERE
2ND ALBUM HERE
