Old 26th August 2010, 11:25 PM
Darryl Darryl is offline
Default Suspension Bracket Jig
Hello there,
Im at the stage of my build that im puttin on the suspension brackets,
I was wondering, How have you guys done it? and what is the easiest way?
Thanks,
Darryl
P.S.
(Im new to the forum!)
Old 27th August 2010, 07:10 AM
David_17's Avatar
David_17 David_17 is offline
have a look here http://www.haynes.co.uk/forums/showthread.php?t=4678
*updated 7/6/11*
Old 27th August 2010, 09:26 AM
Jimmyd Jimmyd is offline
There are a set of jigs I had cut to Davids design floating about the list. Maybe whoever has them could raise their hand and pass on when finished with.
J
Old 27th August 2010, 09:17 PM
David_17's Avatar
I made mine out of wood, worked fine
*updated 7/6/11*
Old 27th August 2010, 09:25 PM
Eternal Eternal is offline
I have the current ones atm just recieved them from Twinturbo. Not started on the brackets tho but will try and get them done soon as i can. But dont want to rush it as the suspension brackets is a thing i really dont want to mess up
Skyline Roadster
Old 27th August 2010, 09:35 PM
I farmed mine out to Handy & Saturn in the end as I was worried the chassis I had may not be too good.
Jimmys Jigs are fantastic though.
Old 27th August 2010, 11:38 PM
Thanks for the replies lads,
I made a jig out of a bit of scrap i had lying around for the rear brackets
the jig is similar to the type that the book uses for the front brackets.
I hope to start on the front brackets tomorrow.
Thanks again,
Darryl
