Old 5th September 2010, 07:45 PM
shh120m's Avatar
shh120m shh120m is offline
Default Finally got things underway
Well, i finally got going today. I finished building my table, got the template lines drawn and got the chassis foundation tubes in place and tacked. Unbelievably everything has gone to plan so far
heres a couple of snaps from build day one...
Old 5th September 2010, 07:56 PM
David_17's Avatar
David_17 David_17 is offline
Hope you weren't on the fosters before you tacked the first tubes in place
Good luck with the build and keep us updated.
If you're ever in stockton you're welcome to pop over and have a look at my build and a chat, then Saturn's not far up the road too. HAndy's another local too
*updated 7/6/11*
Old 5th September 2010, 08:02 PM
shh120m's Avatar
cheers bud, im often up your way as me old man lives in stockton
Yeh, i stopped after one can of lager just incase
